Configuration of VWIC-2MFT-E1 on Cisco 3845 router
Aug 28th, 2007
Please see attached word document for details.
many thanks
purohit_810 Wed, 08/29/2007 - 05:26
By default it takes CRC-4 framing, Please try framing no-crc4 command under the Controller (Interface ) and try.
Second, Use Extended Access-group list, mean instead of 1 access-group use 101. and that muct be permitted in access-list.
Third.. check keep alive.
four.. Check correct switch type that is provided by ISP.
This is only end to end solution for L-2 Down.
Dharmesh Purohit
tutinco Wed, 08/29/2007 - 17:00
Thanks Dharmesh,
The E1 service uses CRC4 Framing and HDB3 Line Coding. I will check all the others.
Thanks again & kind regards
