Router problem .
Aug 28th, 2007
I have aproblem in my router as follow :
I can ping " ICMP request " our remote sites from my local machine , but i cannot ping this remote sites from the router itself although the router is the gate way of the local machaine .
Overall Rating: 4.5 (2 ratings)
smothuku Tue, 08/28/2007 - 23:54
Hi ,
Have you tried extended ping from your router to remote site ..
Jon Marshall Tue, 08/28/2007 - 23:58
As suggested by Satish you should run an extended ping with the source IP address being the interface of the router that connects to your LAN. The problem may well be that when you ping from the router it is using a different interface as the source IP address and the remote site does not know how to route back.
mmousa_dpa Mon, 09/17/2007 - 03:31
sorry for my delay to replay i was very busy
i ping another remote sites from the router and it succeed also i ping the remote site concerning the problem using the source ip address but i obtained no replay
please help me
smothuku Mon, 09/17/2007 - 04:10
Hi ,
check whether the routes are given on remote site router to u r local router network.
Try to do extended trace from your router and paste it in forum.
It is better check the routes configured on both the routers once if you are not using any routing protocal.
If possible paste config of both the routers.
