mac address filter
mframadan
how to deny specfic mac address to access specfic server on cisco switch 6509 hyprid IOS
Jagdeep Gambhir
Level 10
Level 10
Hi ,
From 7.6, port Security has a feature that would do it,
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_6/confg_gd/
sec_port.htm#wp1022694
set cam filter
That will block ANY frame with that source address, that computer won't be able to get
into the network AT ALL. As soon as the switch receives a frame, it always checks it
against the CAM table, it will find that address marked as "filter", so it will discard
the frame.
~JG
purohit_810
Level 5
Level 5
You can anable port security on that interface.
set port security 2/1 enable
Console> (enable) set port security 2/1 enable 00-90-2b-03-34-08
Port 2/1 port security enabled with 00-90-2b-03-34-08 as the secure mac address
Trunking disabled for Port 2/1 due to Security Mode
Console> (enable)
Where 2/1 is the Server port.
You can see more in detail on below link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/7.x/configuration/guide/sec_port.html
Dharmesh Purohit
