VPN Concentrator Identity Certificate
Aug 29th, 2007
I tried to enroll an Identity Certificate via PKCS10 Request (Manual) and choosed a 2048 bit RSA key.
The problem is that RSA key is only 2047 bit long. I have tested it with openssl. The Concentrator GUI says the key is 2048 long.
How can I get a certificate request with a 2048 bit RSA key?
I need a really 2048 bit RSA key because the CA
does not support smaller keys.
