4506 Access Switch Restarted
suhail.nedaria
Hi i had an weird problem,one of my access Switch (4506) got restarted without any reason.When i check in logs it doesnot show me anything.Can any one help me what is the issue.Please find below config on my switch.
cisco WS-C4507R (MPC8245):
ROM: 12.2(31r)SG2
Version 12.2(31)SG1.
IF any one required anything else let me knw.Thanks
11 Replies 11
b.petronio
Level 3
Level 3
U could check the bootflash, searching for some file named crashinfo_yyyymmdd-hhmmss
"show bootflash:"
type "more bootflash:_yyyymmdd-hhmmss"
and copy it to the output interpreter in cisco support tools.
Best Regards,
Bruno Petr?nio
thanks for reply,
I have gone through ur procedure ,crashinfo file is not generated.
show slot0: ?
dir crashinfo: ?
Could u paste the show version, of the equipment ?
Best Regards,
Bruno Petr?nio
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(31)SG1, RELEASE SOFTWA
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 27-Nov-06 20:21 by kehsiao
Image text-base: 0x10000000, data-base: 0x113B349C
ROM: 12.2(31r)SG2
Dagobah Revision 226, Swamp Revision 34
PUN1FS07 uptime is 13 weeks, 4 days, 2 hours, 3 minutes
Uptime for this control processor is 13 weeks, 4 days, 2 hours, 4 minutes
System restarted at 15:48:22 IST Sat May 26 2007
System image file is "bootflash:cat4500-ipbase-mz.122-31.SG1.bin"
cisco WS-C4507R (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX11040JY9
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
3 Virtual Ethernet interfaces
240 FastEthernet interfaces
2 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Are u sure this is the same equipment ?
First u point a 4506, now give me a 4507R version summary.
I dont see anything wrong on this one.
When did u experienced the reset u were talking about. This one was 13 weeks, 4 days, 2 hours, 3 minutes ago, by power on.
Best Regards,
Bruno Petr?nio
sorry it is 4507R
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASE-M), Version 12.2(31)SG1, RELEASE SOFTWARE (fc4
ROM: 12.2(31r)SG2
PUN1FS07 uptime is 13 weeks, 4 days, 2 hours, 12 minutes
Uptime for this control processor is 13 weeks, 4 days, 2 hours, 13 minutes
Configuration register is 0x2102.
it rebooted 2 weeks ago.
This one has also been up for 13 weeks , it has not restarted in the past 2 weeks .
sorry Glen
ROM: 12.2(31r)SG2
PUN1FS06 uptime is 2 weeks, 14 hours, 51 minutes
Uptime for this control processor is 2 weeks, 14 hours, 52 minutes
System returned to ROM by abort at PC 0x0
System restarted at 03:15:06 IST Wed Aug 15 2007
Processor board ID FOX11040LAK
Last reset from Abort
2 Virtual Ethernet interfaces
The configuration register was changed since last restart ??
It's not showing nothing, but we never know.. :)
With that symptom was excepting to see :
Configuration register is 0xyyyy (will be 0x2102 on next reload)
Best Regards,
Bruno Petr?nio
There are a lot of reasons that the switch may have been restarted and not all of them are switch issues. I'd hate to rehash old questions but these are the basics that might need to be run through first:
1. Is the switch on an UPS?
2. Are both power supplies on the same circuit?
3. Is the switch in a secure room?
4. Who else has access to the switch?
Often I find that my issues are the result of either overtaxed circuits or someone kicking a power cord.
Do you have any type of system logging? The event was over 2 weeks ago so show log will most likely not show any events that happened before the restart but it might be worth a look. You also may want to see a 'show power' and make sure you aren't overtaxing the power supplies.
Paul
anmagiera
we seem to have the exact same problem with our Cat 4506 right now. It reboots itself about every 17 hours. A "sh ver" shows the line "System returned to ROM by abort at PC 0x0 "
but the register is set to 2102.
Did you solve the problem last year ? If yes, can you remember how ?
Thanks a lot,
Andrea
