ASDM 6.0(.2) & demo mode.
Aug 29th, 2007
Hi all,
I have a question related to ASDM 6.0.2 running in demo mode.
I can browse and configure parameters in ASDM and apply it.
But if I configure SSL VPN how can I test
it? How can I test configuration of AnyConnect? I see that I connect into localhost:55000 but where are changes applied?
j-block Wed, 09/05/2007 - 13:11
There is no limitation in fuctionality for ASDM running in demo mode. For checking the configuration of SSL vpn or Anyconnect vpn the best way is to use a client to connect to the device after the configuration is applied to the device. To load the configuration to the ASDM demo, you have to copy it to the ASDM demo directory. When pushing configuration to the config, you have to manually copy the commands to the config file in the proper section.
