Cisco 800 ipsec ike tunnel
Aug 29th, 2007
I have some doubts about a work i have to make in the next few days and I'm not very fond in remote access. I will have to configure a Cisco 800 on a remote side (it`s an employee's house). The central site is already configured. The scenario is something like this.
On the central side there is Cisco (don't now what type) and has a config like this (the IPs have been hided):
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key "something" address 80.x.x.x no-xauth
crypto ipsec transform-set ipsec3DES esp-3des esp-md5-hmac
crypto map tunnel 26 ipsec-isakmp
description remote site 192.168.12.x
set peer 80.x.x.x
set transform-set ipsec3DES
match address 126
access-list 126 permit ip 10.5.0.0 0.0.0.255 192.168.12.0 0.0.0.255
The 80.x.x.x is the public IP of my remote router. They have in their own outside port, a termination tunnel with IP 195.x.x.x Which is where i will have to point back in the peer command.
The configuration isnt't really very difficult. In fact, the configuration in my 800 router would be something like this:
encr 3des
group 2
crypto isakmp key "something" address 195.x.x.x no-xauth
set peer 195.x.x.x
match address 126
access-list 126 permit ip 192.168.12.x 0.0.0.255 10.5.0.0 0.0.0.255
ethernet 0
ip address 192.168.12.x 255.255.255.0
serial 0 --> (It isn't a serial, first problem)
ip address 80.x.x.x mask
crypto map tunnel
Now, the person at home where the 800 will be installed, has a DSL connection with a ISP. He has another router (3COM) and uses that router to access the internet. The 800 router will only be to access resources in his office.
My question is, will it work with only that configuration? Do I need to configure adsl with the actual ISP the employee has before creating the tunnel to the office?
Like you can see in the last configuration, I applied the "crypto map tunnel" command to a serial port, but a Cisco 800 doesn`t have a serial port. Where do I configure the 80.x.x.x IP with the crypo map statement?
I was thinking about creating a "tunnel 0" interface and the applying everthing there, but i think it won't work because there's nothing to do with GRE tunnels.
Is there a real need to configure the new 800 router with dsl configuration tu access the office site?
beckerola Wed, 08/29/2007 - 21:30
I have been investigating and maybe the solution would be creating a ATM interface and apply there my public IP address along with the vpi/vci configuration, and also the crypt map. I think it will be enough with that and the IPSec/IKE configuration to form the tunnel.
