MPLS P and PE physical connectivity
Aug 29th, 2007
Hi all,
I have a question regarding the physical connectivity between a P router and a PE router. Some are saying it's best practice to use two 2960G, but I am not convince. Why not connect both P and PE directly? That would probably be more efficient as well.
Martin
Overall Rating: 4.5 (2 ratings)
mheusing Wed, 08/29/2007 - 05:51
Hi Martin,
The connectivity between PE and P in a MPLS environment largely does not depend on MPLS features but on other network design considerations like bandwidth, available cabling, intermediate equipment required, f.e. POS or ethernet, distance between P and PE - to name just a few. It is perfectly OK to have PE and P connected back-to-back.
There are many networks in service provider or enterprise environments, where exactly this is implemented in parts of the network. There are even large MPLS networks without any 2960G interconnecting PE and P routers.
Your information about the usage of 2960G might stem from another requirement; for the MPLS P or PE functionality it would not make a difference. So I would not call it best practice without specifying in more detail, which other requirements lead to this statement.
Hope this helps! please rate all posts.
Regards, Martin
