Cisco IP Voice Media Streaming App Errors: kDownloadMOHFileFailed
Aug 29th, 2007
Anyone knows what is this error? I'm getting alot of MOH errors.
Eugene
Event Type: Error
Event Source: Cisco IP Voice Media Streaming App
Event Category: None
Event ID: 3
Date: 8/29/2007
Time: 9:00:53 PM
User: N/A
Computer: CM2
Description:
Error: kDownloadMOHFileFailed - Download request failure.
File Name: SampleAudioSource.ALAW.wav
App ID: Cisco IP Voice Media Streaming App
Cluster ID: StandAloneCluster
Node ID: 1.1.1.1
Explanation: The TFTP download request failed.
Recommended Action: Validate the TFTP IP address in the database and that the file exists..
Overall Rating: 4 (1 ratings)
mchandak Wed, 08/29/2007 - 05:28
  • Gold, 750 points or more
Can you check the IP Address under the Service Parameters for IP Voice Media Streaming Application and confirm that it is a valid IP. To do the same go to CCMAdmin page, Service | Service Parameters | Select CallManager | From service list, select IP Voice Media Streaming Application. Once the page loads, hit on Advanced button and here you should see the TFTP Server info mentioned, it should either be 127.0.0.1 or point to the server which has TFTP Server service running.
If the above is valid, then check the TFTP Server to see if the file exists at C:\Program Files\Cisco\TFTPPath\MOH folder.
Hope this helps
eug-c Wed, 08/29/2007 - 21:29
Thanks for your reply.
I have verified that IP address is 127.0.0.1 for all TFTP servers.
Also I have copied all files in the MOH directory from the primary TFTP server to the other TFTP servers.
Is there anything else I can check?
Eugene
mchandak Thu, 08/30/2007 - 03:56
Did you reset the MoH Server after that ? If this does not solve the issue, please enable Detailed IP Voice Media Streaming App traces and attach the lastest one to this post
lpannacci Wed, 09/12/2007 - 23:13
Hi Eugene,
I'm encountering the same problem with a server running CM 4.2(3)sr2b. I have 2 subscribers with active IP voice media streaming service and from one of them I receive lot of "download request failure" error messages. I checked the tftp server IP address and directory and they are ok.
Did you find a solution?
Lucia
