wildcard masks
Aug 29th, 2007
Hi all, can anyone tell me how we work out what the wildcard mask is ?
royalblues Wed, 08/29/2007 - 05:43
A simple method would be to subtract the subnet mask from
eg. if you need to know the wildcard mask for then you can do - =
HTH, rate if it does
mohammedmahmoud Wed, 08/29/2007 - 05:44
hi Carl,
Wildcard mask is a bit matcher which is the inverse logic of the subnet mask (a subnet mask of corresponds to a wildcard of, just inverse the binary 1s to 0s and vice versa) -> 0 = match and 1 = ignore, accordingly a wildcard of = host, since all bits must match , and = any, since we don't care what any bit is.
Mohammed Mahmoud.
massimiliano.se... Wed, 08/29/2007 - 05:46
The wildcard mask is an "inverse mask", that is: bit 0 means "care" and bit 1 means "don't care".
An example of application is an access list:
access-list 100 deny
Conversion in binary -> 00000000.00000000.00000000.00001111 -> 11000000.10101000.00000001.0000000
The interval of denied addresses is:
From 11000000.10101000.00000001.00000000 to 11000000.10101000.00000001.00001111
In decimal
From to
That is all addresses from to are denied.
I hope this helps.
Best regards.
