Problem with POS interface initialization
Aug 29th, 2007
Hi all,
I got a problem when trying to configure IP address in a POS interface that will receive a new link STM1. This interface is new, that is, it never worked before.
After installing it, the router recognize it normally (see below)
interface POS6/0
no ip address
shutdown
no cdp enable
...but when I configure the ip address, the router stucks in such a way I have to restart it, removing then, the card.
Has anyone seen such a behavior?
The command "show ver" follows below. Any help will be greatly appreciated.
Thanks a lot!
Gustavo
show ver
show version
Cisco IOS Software, 7200 Software (C7200-IS-M), Version 12.3(7)T3, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2004 by Cisco Systems, Inc.
Compiled Tue 20-Jul-04 03:30 by eaarmas
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.1(14)E6, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ufv uptime is 18 hours, 13 minutes
System restarted at 17:23:11 UTC Tue Aug 28 2007 System image file is "disk0:c7200-is-mz.123-7.T3.bin"
Cisco 7206VXR (NPE400) processor (revision A) with 229376K/32768K bytes of memory.
Processor board ID 31783703
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
6 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb0_mb1 has 600 bandwidth points PCI bus mb2 has 480 bandwidth points
3 FastEthernet interfaces
18 Serial interfaces
1 Packet over SONET interface
125K bytes of NVRAM.
47040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
8192K bytes of Flash internal SIMM (Sector size 256K).
