PRI Group - problem
Aug 29th, 2007
I'm trying to configure the PRI group setting on Controller E1 0/0 on 2600 12.2 to pri-group timeslots 1-31 and am getting the following message.
%Voice interface must be shutdown before updating configuration.
I tried issuing the shutdown command to the controller and other interfaces, but the same thing happens.
Has anyone come accross this?
J Mack
Overall Rating: 4.5 (2 ratings)
mchandak Wed, 08/29/2007 - 06:43
  • Gold, 750 points or more
incase you have only shutdown the controller, you need to shut the serial Interface (Interface serial 0/0"15" and voice-port 0/0 as well. Once all the three are shut, you should be able to add change the pri-group config. Incase this also does not work, please attach the show run from your router to this post
mchandak Wed, 08/29/2007 - 07:07
By voice port, I did not mean Ethernet Port. From the config, this is what I was referring to:
voice-port 0/0:15
cptone GB
So, to be able to change your config, do the following:
voice-port 0/0:15
shutdown
interface Serial0/0:15
shutdown
controller E1 0/0
shutdown
no pri-group timeslots 1-30
no shutdown
voice-port 0/0:15
no shutdown
You can copy paste the lines above undeer config mode and this should resolve the issue. Also, please ensure that you do this during non production hours as this would take the PRI down.
johnnymac Wed, 08/29/2007 - 07:23
Thanks a lot, will try this evening.
J Mack.
johnnymac Thu, 08/30/2007 - 00:56
I followed what you suggested and it worked. Thanks a lot, I have rated your posts.
Unfortunately it didn't resolve my problem. What I was trying to do was enable channel 30 for a call monitoring software application. Apparently it only talks to the router up to channel 29?
Was i approaching this in the right way?
After configuring pri-group timeslots 1-31 w could not get an outside line.
Have I missed something.
J Mack
mchandak Thu, 08/30/2007 - 03:48
Well, once thing that you can check for is if the pots dial-peers have the line "voice-port 0/0:15" mentioned.
Also, if the monitoring Software is not able to use port 30 and 31, I think it has to be the setting on the software itself. There is nothing that can be done on the router to enable this.
