IPSEC VPN on ASA 8.0(2) request timed out
Aug 29th, 2007
I need to help in identifying what this warning message in my ASA logs say and what i would need to do inorder to correct this problem. I currently have an ASA firewall terminating my end of the VPN tunnel and a Multitech Firewall at my remote network. Below are the log entries from my ASA firewall:
3|Aug 29 2007|14:44:08|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Removing peer from correlator table failed, no match!
3|Aug 29 2007|14:44:08|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, QM FSM error (P2 struct &0xd575b350, mess id 0x103cc666)!
3|Aug 29 2007|14:44:08|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, QM FSM error (P2 struct &0xd572e928, mess id 0x64598150)!
3|Aug 29 2007|14:44:08|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, QM FSM error (P2 struct &0xd57589a0, mess id 0xd837eb84)!
3|Aug 29 2007|14:43:43|713122|||IP = 207.224.xxx.xxx, Keep-alives configured on but peer does not support keep-alives (type = None)
3|Aug 29 2007|14:43:43|713119|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, PHASE 1 COMPLETED
4|Aug 29 2007|14:43:43|713903|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Freeing previously allocated memory for authorization-dn-attributes
4|Aug 29 2007|14:43:42|113019|||Group = 207.224.xxx.xxx, Username = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Session disconnected. Session Type: IKE, Duration: 0h:00m:01s, Bytes xmt: 0, Bytes rcv: 0, Reason: Phase 2 Mismatch
07|14:43:33|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Removing peer from correlator table failed, no match!
3|Aug 29 2007|14:43:33|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, QM FSM error (P2 struct &0xd575aad8, mess id 0x4b2a62df)!
3|Aug 29 2007|14:43:33|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Removing peer from correlator table failed, no match!
And also I've noticed a Request timed out when i constantly ping a host in the remote network and this normaly happens during the this part of the log below:
3|Aug 29 2007|14:43:42|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, Removing peer from correlator table failed, no match!
3|Aug 29 2007|14:43:42|713902|||Group = 207.224.xxx.xxx, IP = 207.224.xxx.xxx, QM FSM error (P2 struct &0xd5663e58, mess id 0x3051851)!
3|Aug 29 2007|14:43:41|713122|||IP = 207.224.xxx.xxx, Keep-alives configured on but peer does not support keep-alives (type = None)
Reply from 192.168.105.xxx: bytes=32 time=339ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=332ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=326ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=325ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=331ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=324ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=334ms TTL=63
Request timed out.
Request timed out.
Reply from 192.168.105.xxx: bytes=32 time=347ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=337ms TTL=63
Reply from 192.168.105.xxx: bytes=32 time=338ms TTL=63
mattiaseriksson Wed, 08/29/2007 - 08:06
Do you have a dynamic crypto-map attached to the crypto map on the ASA? Then check that the sequence number is higher for the dynamic crypto-map.
The Keep-alives messages should not be an issue.
brianbono Thu, 08/30/2007 - 04:49
anyways thanks for the help mattiaseriksson :)
i just took the:
crypto map outside_map 1 set pfs
and it finally worked :)
