Keywork "track" and "DHCP" on the same route
Aug 29th, 2007
Hi all
Can someone tell me why I coulnd't put those keywords "DHCP" and "track", on the same route. I must use an interface route because my ISP's address are assign dynamically.
Overall Rating: 4 (1 ratings)
Edison Ortiz Wed, 08/29/2007 - 07:16
  • Hall of Fame,
    Founding Member
You can create an ip route with track by using the egress interface as the keyword which enables you to use the track option.
For instance, if the egress interface is serial 0/0.
ip route 0.0.0.0 0.0.0.0 serial 0/0 track [valule]
netadmindetail Wed, 08/29/2007 - 07:30
I already use the egress interface as the keyword, but it's not a serial interface
Router:Cisco 831
ex.:ip route 0.0.0.0 0.0.0.0 Ethernet 1 track 1
But instead of using the keyword track, I must use the keyword DHCP to let the router know that he will receive he's gateway from DHCP.
Like this : ip route 0.0.0.0 0.0.0.0 Ethernet 1 DHCP track 1, but I can't put those two keyword on the same route.
Does it exist an other way to do the same thing ?
Edison Ortiz Wed, 08/29/2007 - 07:34
  • Hall of Fame,
    Founding Member
I'm assuming that using
does not work in your environment ?
The packets will be sent to the Ethernet interface whether the interface got its IP via static or DHCP.
netadmindetail Wed, 08/29/2007 - 07:46
Usually yes. But some of my customer's ISP have something wrong with their "proxy arp" on edge routeurs. So I must use the DHCP keyword to be able to connect on the internet.
Edison Ortiz Wed, 08/29/2007 - 07:52
  • Hall of Fame,
    Founding Member
Perhaps they've disabled proxy-arp at their end for security reasons. I'm afraid it can't be done with dhcp and track option on the same ip route statement.
netadmindetail Thu, 08/30/2007 - 06:57
Can I do tracking in an other way ?
(Like doing it to automatically shut down the interface if the tracking condition is reach, instead of remove the static route from the routing table if the tracking condition is reach. Because if the interface is shutdown, the default route will be remove from the routing table even if this is a ditrectly connected route.)
Edison Ortiz Thu, 08/30/2007 - 13:31
  • Hall of Fame,
    Founding Member
Shutting an interface down can be down with kron, however - I don't have time to lab it up at the moment.
I don't any other suggestion, sorry.
netadmindetail Fri, 08/31/2007 - 04:55
dont't be sorry.
I found an other way. I change the AD the my default route to an higher value and pass my other default route before it with another tracking object that's negate the first one.
But I'll check for kron too.
Thank you very much
