sea_log.dat
beth-martin Tue, 09/04/2007 - 06:54
  • Bronze, 100 points or more
If you want to read the contents of the SEA (System Event Archive) file use the following syntax:
Router#show logging system disk sup-bootflash:sea_log.dat
szahid Tue, 09/04/2007 - 09:37
  • Silver, 250 points or more
Question1 : What s that file in sup-bootfl.
System Event Archive (SEA) is a logging feature that allows all the modules in the system to report major and critical events to active SP and the active SP will log these events to non-volatile storage.
SEA can help debug customer issues without reproducing the problem ( like a black box ).
SEA ok ! How do I do do read it ?
Some one already responded regarding that.
What happens if his size is GT than sup-bootflash , or EQ ? GT seems to be more ...
System event archive can only grow to 10% of whichever file system / storage is being used to store the SEA upto a maximum of 32 MB.
Salman.
