SDM launching problems....
Aug 29th, 2007
Having trouble getting SDM to work on an 1841 router.
SDM version 2.4.1
Router Version 12.3(8)T6
Win XP
IE and Firefox
Java Runtime 5 update 10
The application begins to load then freezes on the following message.
"Please wait while the SDM is loading the current configuration from your router
Populating modules... - NAC"
Any ideas welcome. Thanks.
Overall Rating: 4 (1 ratings)
mohammedmahmoud Wed, 08/29/2007 - 08:36
hi,
Make sure that you've permitted it in the Win Firewall, and then before launching SDM clear the browser cache.
HTH,
Mohammed Mahmoud.
acomiskey Wed, 08/29/2007 - 08:55
Thanks Mohammed, I rolled back to SDM v. 2.2 and was able to connect through firefox. Still no luck with IE.
Unfortunately, I'm having bigger issues at the moment.
