Downgrading a 2960 IOS
boondocker
I have a pair of new 2960-24TC switches and need to downgrade to 12.1c...does anyone have a step procedure on how to do this?
ankbhasi
Hi Friend,
AFAIK 2960 does not support 12.1 release and only support 12.2.x releases.
Ankur
*Pls rate all helpfull post
...yes, I ment 12.2...thx.
Hi Friend,
If you want to downgrade from spme 12.2.x train to some lower 12.2.x train it is very well possible and you have to follow the same procedure what you follow for upgrade.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2960/12237se/scg/swiosfs.htm#wp1020606
Just remember to take the backup of your config because sometime downgrading may result in loss of configuration.
Ankur
Perfect...thanks
