4402 Wireless Controller Supported AP's
Aug 29th, 2007
Even though the main page says "25 access points supported" I cannot register more than 12. Where do I find the licensing information please?
Overall Rating: 4 (1 ratings)
ericgarnel Wed, 08/29/2007 - 11:04
  • Gold, 750 points or more
Do you have both ports 1 & 2 plugged in and enabled? Also, are the switch ports set in trunking mode?
p21 Thu, 08/30/2007 - 01:18
There is only one port on the controller connected to the network. That switch port is set to trunk. Thanks.
ericgarnel Thu, 08/30/2007 - 06:18
The remaining APs will register when you hook up the other port
p21 Thu, 08/30/2007 - 07:43
What is involved? Do I need to enable spanning tree, assign another AP manager IP address etc?
ericgarnel Thu, 08/30/2007 - 07:50
Configure the port on the switch to trunk in dot1q encap and remove any vlans that will not be needed on the wireless network.
The default settings on the WLC should be fine.
You will have to go into each dynamic interface on the WLC and set the other port as the secondary, if not set already
p21 Thu, 08/30/2007 - 07:59
Thanking you. I will give that a try.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
