ETA for Vista/VPN Client error 424 fix?
Aug 29th, 2007
Hello all,
Our company is holding off on approving Vista until there is a better way of handling the issue CSCsi26106 under Vista with the VPN client (Failed to enable virtual adapter error). I know about the workaround, but, I've found on my personal Vista machine that I can't always get it working even with the workaround. Does anyone know if there's an ETA on when this issue may be resolved?
purohit_810 Wed, 08/29/2007 - 11:20
See in device manager, VPN adapter driver.
Update windows vista from microsoft.. and try.
If you have installed NORTON antivirus it does always conflict.. uninstall it.
Dharmesh Purohit
