mgcp gateway, PRI, ATA fax problem
Aug 29th, 2007
I have a new implementation with fax machines behind ATAs going through an MGCP gateway with a PRI. Many faxes are stalling out. They connect and die. This is my first time to use ATAs for anything. What are the gatchas with this?
didyap Tue, 09/04/2007 - 11:38
verify the Audio port and the connect mode settings. Have you configured 'mgcp modem passthrough voip mode nse' command in the mgcp router
