Error after upgrading to newest VPN client
Aug 29th, 2007
Anyone gotten the following message after upgrading to either of the newest VPN clients? 4.x.x or 5.x.x?
secure VPN connection terminated locally by the client. the remote peer is no longer responding. -> reason 412
My clients either can't connect, or they constantly get disconnected.
purohit_810 Wed, 08/29/2007 - 10:49
VPN adptor has also drivers.
Can you check into device manager of that PC all are drivers present for VPN adapter.
Dharmesh Purohit
m.saunders Wed, 08/29/2007 - 10:52
I'm not quite sure what you're asking. if the VPN adaptor was not present, they wouldn't be able to connect in the first place. One lady can connect, but she constantly gets disconnected.
m.saunders Tue, 10/09/2007 - 12:20
Hi ashley, I'm not quite sure what you mean. Why does policy 10 work over policy 5??
When you set the policy you give it a number. When the client starts to negotiate it starts at the lowest policy and works its way through, however, I have found that the client negotiation will often stop at a partial match policy, e.g.
crypto isakmp policy 5
authentication pre-share
encryption aes-256
hash sha
group 5
lifetime 86400
crypto isakmp policy 10
encryption aes-256
hash sha
group 2
lifetime 864000
Lets say that the client will only work with policy 10, however, as it negotiates policy 5 it finds a match with AES and SHA but will not work with group 5, it can hang. the next time the client logs in it dismisses policy 5 and goes to 10, works perfectly. Move policy 10 to 5 and it will work every time.
Hope this helps, please let me know if this cures the issue.
m.saunders Thu, 10/11/2007 - 05:11
Thanks Ashley. Actually, all of my policies are pretty much the same so I don't think that's the issue:
encr 3des
hash md5
group 2
crypto isakmp policy 11
encr 3des
group 2
crypto isakmp policy 20
encr 3des
hash md5
group 2
crypto isakmp policy 30
encr 3des
hash md5
