IOS image with IPSEC tunneling
Aug 29th, 2007
Hey Folks,
I'm trying to find a 12.3 IOS image that allows me to create IPSEC tunnels.
I downloaded 12.3.23 (GD) with the Enterprise Plus IPSEC 3DES feature set.
When I installed it on my 2621XM router, I noticed that I cannot type in commands such as "crypto isakmp, crypto ipsec transform-set", etc.
Can anyone tell me which feature set I need to download so that I can basically follow this doc: http://www.cisco.com/warp/public/707/ios_meshed.html
SM
purohit_810 Wed, 08/29/2007 - 10:41
  • Silver, 250 points or more
See available command in 12.3 IOS...
You can use command lookup tool for available commands in IOS. For that you required Partner login..
Both commands are available at 12.3 IOS.
See attachment.
Screenshot of Cisco site command lookup tool.
Dharmesh Purohit
