ACLs - Need Help
Aug 29th, 2007
I have configured ACLs for accessing/managing storage devices in DMZ from LAN. Client is able to telnet to storage devices for e.g. he is able to telnet to a.b.c.d on port 443, but when he tries to browse https://a.b.c.d it asks for download of certificate for https access but after that stucks without giving any error while one of the other pc from DMZ is able to access that URL without any delay.
I have enabled logging(informational) for those rules. It's showing logs of connection built. Not found any drop related to those ACLs.
Thanks & Regards,
sadbulali Wed, 09/05/2007 - 13:13
You should check if any device in between is dropping the HTTPS packets. This may be due to packets or the pre shared key getting corrupted. This can be checked in router logs. You have to check all router logs as these are not specific to any ACL rule dropping the packets.
Trending Topics: Storage Networking
