ASA 7.2.(3) cluster: secondary unit leaking memory
I have two ASA5520s, both running 7.2(3) in an Active/Standby cluster. Since moving them to 7.2(3) it appears to me that the Standby unit is leaking 100kb of memory every hour; it was up for 5 days and suddenly started complaining about being out of memory, while the Primary's Used Memory was holding steady.
Anybody else seeing this? I have a TAC case open, but they don't know of any leaks in 7.2(3)
smahbub Wed, 09/05/2007 - 06:26
Check the command - logging flash-bufferwrap is configured. Because it sometime cause the memory blog and remove the command if configured.
