08-29-2007 11:05 AM
I'm using WAAS 4.0.13. When I make a change to a WAE from the manager, the change takes effect immediately. However, if I log into the WAE and look at the startup config, the change is not saved yet. How long does it take for the change to be saved to the startup config?
08-29-2007 11:15 AM
Wendy,
Changes are written to the startup-config every 10 updates or 1 hour, whichever comes first. Changes made since the last time the startup-config was updated are stored in a local log file. The changes in the log file are reapplied when the WAE boots (right after the startup-config is applied).
Zach
08-29-2007 11:31 AM
Thanks!
