Firewall Log Analyzer
Aug 29th, 2007
We currently have a PIX firewall and I am wondering what would be a good real time log anaylzer. Currently we are using ManageEngine's Firewall Analyzer but have run into some issues with the product.
Chris_FWA Sun, 02/05/2012 - 05:06
Craig,
Thank you for the post. I believe you must have used Firewall Analyzer's basic edition (Firewall Analyzer 4), and the application has reached various milestones in the past. The latest version of ManageEngine Firewall Analyzer is 7.2
The product almost support all the leading vendors in the industry. Our application is segregated in to the three categories and they are,
    1.Traffic
    2.Security
    3.Management
1. Traffic Statistics:
      This will give you the complete bandwidth information that was transacted through out the network with multiple drill analysis such as Source, Destination, Protocol, Hits, Bytes Sent, Bytes Received etc.
You can even do capacity planning and forecasting with the product.
2. Security Statistics:
      Security Statistics (Reports) will display all malicious events in your network. It will help you to know the various threats and attacks to the company from outside to inside and vice versa.
3. Management Statistics:
      This will help you to do audit and security configuration analysis which includes change management, compliance report. This will point out the loop holes of the network and assist you to fix it.
Why Firewall Analyzer?
  • Support for Firewall and security devices from multiple vendors
  • Real-time bandwidth monitoring
  • Employee internet usage with URL monitoring
  • Real-time alerting
  • Firewall Change Management reports
  • Security Audit & Configuration Analysis reports
  • Diagnose live connections
  • Capability to view traffic trends and usage patterns (Capacity Planning)
  • Powerful search for forensic and security analysis
  • Multi-level drill down into top hosts, protocols, web sites and more
  • Network security reports
  • Firewall compliance reports
  • Flexible and secured log data archiving
  • Rebranding, User based views and dashboard for MSSP Support
and more
http://www.manageengine.com/products/firewall/features.html
I recommend you to evaluate the fully functioned 30 days evaluation copy and check if it helps you to acheive your use case.
Vignesh.K
Firewall Analyzer
