Good app for making IVR audio prompts?
Aug 29th, 2007
I understand that audio prompts used with various Tcl IVR scripts have to be 8-bit, u-law, 8khz encoding and saved in "au" format. Can anyone recommend a good (preferably cheap or free) application that can create audio files in this format and ideally convert other audio formats to meet these specs as needed?
TIA
Overall Rating: 5 (4 ratings)
marcuscastellanos Wed, 08/29/2007 - 12:21
Flash,
I'm currently using Cool Edit Pro. The newer version is a little more expensive but it has a bunch of options if you really want to get into splicing. The problem is adobe has renamed it and I have no clue how the new version is. If you can find a vendor selling the old ver it should do you good.
Rob Huffman Wed, 08/29/2007 - 15:50
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Steven,
Just to add a note to the excellent info you received from Marcus. The product is now named Adobe Audition. Here is a link, it's quite pricey $$ but very good :)
https://store1.adobe.com/cfusion/store/#loc=en_us&view=ols_prod&store=OLS-US&categoryOID=1172060&distributionOID=105
Hope this helps!
Rob
