Alternate Greeting Error
Answered Question
Have a customer running Unity 4.2(1). WHen using the phone to set alternate greeting the following occurs.
"Attempted to setup my alternate greeting but was unable to set an end date. When I pressed "7" (for seven days later) I got the following message: "This system is temporarily unable to complete your call, please call again later."
Unity immediately hangs up after that.
This issue does not happen every time (about 70% failure). you also get the following two event log errors.
Event Type: Error
Event Source: CiscoUnity_PhraseServer
Event Category: None
Event ID: 10002
Date: 8/29/2007
Time: 2:20:59 PM
User: N/A
Computer: USVM0001
Description:
Script Engine (CDE Script) -- Exception caught and handled in ConvSub.DLL!UtilsDateTime_RunStart.
Event Type: Error
Event Source: CiscoUnity_ConvUtils
Event Category: Error
Event ID: 26
Date: 8/29/2007
Time: 2:21:03 PM
User: N/A
Computer: USVM0001
Description:
Unexpected error occured in the TUI utilities conversation. Technical details - IAvNamedProps::GetPropDate returned [0x80043200] on line 613 of file E:\Views\CU4.2.0.110\un_Conv1\Scripted\ConvSub\ConvUtils.cpp. For furthur investigation, please turn on all the diagnostics for Conversation Utilities.
WHile i wait for the TAC to pick this up - was wondering if ayone has seen this issue before.
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Thu, 08/30/2007 - 05:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Rob Huffman Thu, 08/30/2007 - 05:46
  • Hall of Fame,
    Founding Member
Hi Mike,
You are most welcome! Thanks for posting back with your actual resolution from TAC. 5 points for your good work and for sharing this info to help others :)
Take care,
Rob
