Help configuring E1 for PRI
Aug 29th, 2007
I am configuring E1 for PRI for the first time and am having some trouble. The telco has provided the following information;
- E1 32 channels
- Switch is primary clock
- Framing is CCS
- Coding is HDB3 and CRC on or off
- Signaling protocol is SS7
- Framing (0); Signalling (1); voice (from 2 to 31)
There doesn't seem to have an option for "CCS" framing. Also, I can't seem to change the linecode to HDB3 (it will let me enter the command, but it is not reflected in the running config.)
Can someone help?
-Shikamaru
