NAT and GRE Tunnel
Aug 29th, 2007
I have four router (See Visio diagram attached)
Router A, B, C and D. On router B i have interfaces Gi0/1 which is configured as "ip nat inside" while the Multilink 1 is configured as "ip nat outside", GRE Tunnel 0 is configured with NO NAT.
The Senerio
I want to route RFC1918 IPs between Routers A and D via the Tunnel 0
I am doing NAT on Router B to get to the LAN with a rouable IP addresses.
Success
When traffic flows between LAN Public IP
(Non-RFC1918 Routable) and WAN RFC1918 NAT Translate OK
Problem
From Router D when LAN RFC1918 route traffic thru the Tunnel 0 to Router B I do not want NAT to take place on the Multilink 1. I want real IP address to route through however NAT take plase too.
Question
Knowing that i do Static NAT on Multilink1 How do i allow NAT from LAN
Public IP (Non-RFC1918 Routable) to WAN
RFC1918 10.10.10.10 and also not allow NAT to 10.10.10.10 if traffic originated from LAN RFC1918 via the Tunnel0
Adeolu
bwalchez Tue, 09/04/2007 - 12:07
To add GRE to a working IPSec configuration, follow these steps.
Remove the crypto map from the interface.
Create the tunnel interfaces.
int tunnel
ip address private_ip subnet_mask
tunnel source outside_interface_name
tunnel destination peer_address
Modify the crypto access list as shown below.
access-list acl_name permit gre host tunnel_source_ip host peer_address
Use routing protocol or configure a static route for the remote LAN with the next hop pointing to the tunnel interface.
Reapply the crypto map to the physical interface and the tunnel interface.
