IP Route Question
Aug 29th, 2007
We have two offices. My office has two T1 connections to the Internet. I've ordered Point-to-Point T1 (just the T1 port without Internet connection) to connect our other office to us and to the Internet.
I would like to subnet our class C IP like below:
198.78.142.1 255.255.255.128 (our office)
198.78.142.252 255.255.255.252 (For serial ports that are connecting our two offices)
198.78.142.128 255.255.255.192 (our other office)
I'm having a problem figuring out the "ip route" statements to accomplish the above:
IP route statement for my router here:
ip route 0.0.0.0 0.0.0.0 4.0.240.121
ip route 0.0.0.0 0.0.0.0 38.99.199.153
ip route 198.78.142.128 255.255.255.192 198.78.142.254
IP route statement for our other office:
ip route 0.0.0.0 0.0.0.0 192 198.78.142.253
Are the above ip route statements correct?
Are the Serial configuration for connecting our two offices correct?
-------------- Below is my Cisco router configuration----------
! Connection to Internet from Level3
description to-Internet-1
interface Serial0/0
bandwidth 1536
ip address 4.0.240.122 255.255.255.252
down-when-looped
service-module t1 timeslots 1-24
! Connection to Internet from Cogent
interface Serial1/0
description to-Internet-2
bandwidth 1536
ip address 38.99.199.154 255.255.255.252
ip access-group 111 in
encapsulation ppp
load-interval 30
down-when-looped
no fair-queue
! Connection from our other office
! Point-to-Point - I need to connect them to our Internet
interface Serial0/1
description to-our-other-location
bandwidth 1536
ip address 198.78.142.253 255.255.255.252
encapsulation ppp
down-when-looped
no fair-queue
! Our internal LAN
interface Ethernet0/0
description local_network
ip address 198.78.142.1 255.255.255.128
no ip redirects
ip route-cache flow
half-duplex
no ip http server
ip classless
-------------- Below is our other office router configuration----------
! Connection to main office
description to-our-main-office
interface Serial0/0
bandwidth 1536
ip address 198.78.142.254 255.255.255.252
encapsulation ppp
down-when-looped
no fair-queue
! internal LAN
ip address 198.78.142.129 255.255.255.192
no ip redirects
ip route-cache flow
half-duplex
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 198.78.142.253
comentum Wed, 08/29/2007 - 18:55
Thanks for your reply.
Our Point-to-Point connection has not arrived yet. I'm getting the routers ready.
I wasn't sure if it was possible to subnet one class C address and use it in two locations:
I appreciate all your help - Thank you.
Edison Ortiz Thu, 08/30/2007 - 14:09
Definitely possible and you've done a great job at ip address preservation :)
Joseph W. Doherty Wed, 08/29/2007 - 19:31
I agree with Edison, didn't see any problems with the route statements, nor with the address block usage.
PS:
Some other suggestions.
If your router's and LAN hardware can support it, move to full-duplex (or auto).
Recommend fair-queue instead of FIFO on all your serial links.
