EAP type not configured
Aug 29th, 2007
hi
i have an ACS 1113 ....
i have installed and configured the certificate... and trusted the CA certificate... also i configured the global authentication (enable the PEAP ,EAP-TLS)
no when i try to authenticate (by the wireless) i get failed to authenticate
when checking the ACS failed attempts i find the failure code
- EAP type not configured-
i don?t know why its happing....
but every thing is configured...
Overall Rating: 5 (1 ratings)
Jagdeep Gambhir Wed, 08/29/2007 - 17:18
Please make sure on ACS > Network Access Profiles >
Make sure we have "Grant access using global configuration,when no profile matches" option
selected.
Also make sure on ACS > ACS Certificate Setup > Install ACS Certificate >
Make sure a certificate is installed, if it is installed then click cancel.
Also go to ACS > System Configuration > Global Authentication Setup > Make sure under "PEAP" we have checked "Allow EAP-MSCHAPv2" and/or "Allow EAP-GTC" as applicable.
~JG
mirboukai Thu, 08/30/2007 - 00:35
thank you
the "Grant access using global configuration,when no profile matches" option was not selected.
could you please give me a brief of why do we configure the NAP..
