4404 WLC stuck in boot loop after upgrade
Aug 29th, 2007
In prepping for the upgrade to 4.1.185.0 I've got two controllers at different sites stuck in a boot loop after applying 4.0.219.0. Units will not even get to the <ESC> option menu.
ANy ideas?
dsweeny Tue, 09/04/2007 - 13:44
Did you clear the configuration on the controller by using Option 5 in the boot menu? This will corrupt the boot image. You should not choose the clear config (option 5) from the boot menu on controllers running 3.2.78.0, 3.2.116.21, 3.2.150.6 or 3.2.150.10, 3.2.171.5 or 3.2.171.6, 4.0.155.5 or 4.0.179.8 and 4.0.179.11.
corey.chitwood@... Mon, 09/17/2007 - 07:43
No, did not clear the config.
Cisco TAC has verfied the unit is now a boat anchor and has shipped a replacement. They are doing a n autopsy on theold unit to see what the problem is.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
