cisco SDM
Aug 29th, 2007
Guys can someone please tell m ehoew to get cisco SDM plus if i have cisco 2800.........which IOS is required to install this software.....secondly on cisco website it says that it comes with cisco 2800....i cant find it....can someone please tell me how can i install it and how??? regards
purohit_810 Thu, 08/30/2007 - 07:19
  • Silver, 250 points or more
Q. How do I know if I have Cisco SDM Express or Cisco SDM loaded on router flash?
A. The quickest test is to connect your PC to the lowest-numbered Ethernet port with a cross-over cable and browse to http:// and see if SDM Express or Cisco SDM launch point is present on the resulting web page. Please refer to Cisco Router and Security Device Manager (SDM) Quick Start Guide for PC configuration. Alternatively, you can use the CLI to check that the Cisco SDM files are present in the router Flash memory: enter show flash and look for the Cisco SDM file set: es.tar (for Cisco SDM Express), sdm.tar (for Cisco SDM), ips.tar (for IPS), wlanui.tar (for Cisco WLAN Application), home.tar, home.shtml, common.tar, and sdmconfig-xyz.cfg.
Follow this document:
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_quick_start09186a0080511c89.html
Dharmesh Purohit
