ping command
ilnaiduccna
Hi experts,
In my network I am able to ping from my one of the lan pc to external network but I am unable to do the same thing from my router int. any body can give suggestions.
naidu.
5 Replies 5
Jon Marshall
Hi Naidu
This could well be down to the interface the router uses as it's source IP address when you do the ping.
Could you use the extended ping on the router and when it asks for the source interface use the IP address of the router interface that connects to your LAN.
Jon
Hi Jon,
Thanks for your early reply,
But I am not aware to use extended ping, can you tell what is the extended ping and how, from where shall we use it.
And what is the difference btw extended ping and normal ping (which from router int.)
many thanks in advance.
naidu.
Naidu
Extended ping on a router just gives you the ability to set more options. To use it just type
router# ping
and then hit return and it asks you questions as to what you want to do with the packet. Here's an example from one of our lab routers
2600_rtr1#ping
Protocol [ip]:
Target IP address: 10.5.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 10.15.1.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.5.1.1, timeout is 2 seconds:
Packet sent with a source address of 10.15.1.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
2600_rtr1#
Jon
Hi Jon,
So thanks,
This type I used so many times but I don't know people called this is a extended ping, just small confusion but however my doubt been cleared by jon.
naidu.
c
Did the extended ping (as suggested by jon) work?
