CSM Design question
Aug 29th, 2007
Hi Sir,
I have deployed CSM (part number: WS-X6066-SLB-APC) on a Catalyst 6513 running Cisco IOS software. The CSM software version is 4.2(4).
Please refer to attached network diagram. The CSM is configured for secure/router mode. There's another third-party load balancer in the setup.
There's a plan to remove the third-party load balancer and migrate segments A & B to the CSM and maintain existing operations. Can this requirement be achieved using a CSM?
My existing CSM config is as follows:
vlan C client
ip address ...
gateway <upstream_firewall>
vlan D server
ip address ...
alias ...
Can anyone show me some configuration guides to implement such a design? I understand CSM supports multiple VLANs but how are they configured?
Please help.
Thank you.
B.Rgds,
Lim TS
Jose Garcia Thu, 08/30/2007 - 04:49
Hi Lim,
Looking at the diagram you attached it is possible to use the CSM to load balance traffic to the segments A&B, but you will have to use Secure/router mode between VLAN's C&D, but One-Arm between A&B, this is because of the router in the middle will break the secure mode.
So you don't need to touch the configuration of the Vlans C&D, and here is a configuration guide to use with A&B:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/4.2.x/configuration/guide/netwcsm.html#wp1069935
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns304/c649/cdccont_0900aecd8010e78b.pdf
I hope this helps.
Regards.
Josega.
