CSS 11503 - Redirect from https to http
Aug 30th, 2007
Dear Pro:
I am try to 'redirect' incoming https request to a specific website, for example:
"Incoming->https://www.yahoo.com -->> http://www.yahoo.com", it does not work.
However, it does work for http redirect: "Incoming->http://www.yahoo.com -->> https://www.yahoo.com".
Any good comments? below is my config:
NOT working config:
content testlb_443
balance weightedrr
vip address
url "/*"
protocol tcp
port 443
redirect "http://www.yahoo.com"
Working config:
content testlb_80
balance weightedrr
url "/*"
vip address
protocol tcp
port 80
Jose Garcia Thu, 08/30/2007 - 04:28
It will be expected that the first configuration you mention will not work, let me explain you why:
The Rule testlb_443 is listening in the incoming port 443, which is a port that will carry secure encrypted traffic (SSL), this means that the L5-L7 (which includes the URL) will be encrypted, therefore the CSS cannot match any L5-L7 statement in that kind of request coming to port 443.
So you cannot use URL redirections on Rules that listen on port 443, unless you use a SSL-Module to decrypt the traffic first.
The request for the second Rule testlb_80, will work just fine since it is listening in a clear text port.
I hope this makes sense.
zahkhan Thu, 08/30/2007 - 18:15
The redirect can only be issued once https is decrypted.
Either offload SSL on SSL module and issue redirect, or offload SSL on server and then issue redirect.
