ASA Java RDP fullscreen
Aug 30th, 2007
does anybody know how to make the Java RDP client for the WebVPN in the ASA to run in fullscreen instead of having to specify the resolution you want to run ?
1 vote
systeembeheernsd Fri, 06/11/2010 - 06:42
Someone on the juniper support forum patched it for fullscreen. Maybe someone can alter this to make this work on the ASA plugin.
"I've patched the properojavardp to include a full-screen option, it requires java 1.4 or higher.
The compiled patched version is attached. You can enable fullscreen by adding "
JORGE RODRIGUEZ Thu, 06/17/2010 - 23:30
What version of rpd-plug in are you using?  try using latest release version  - rdp-plugin.090915.jar
I have tested on varios OS platforms  this latest plug-in  version win-xp, vista 32/64 bit, windows7  with successfull full screen without specifying screen resolution .
