LWAPP access points are unregistering from the controller
Aug 30th, 2007
Our wireless controller network designed with one 4402 controller and 30 LWAPP 1000 series access points.
all lwapp access points are suddenly unregistering from the controller and registering with controller after few minutes. It was happen randomly 2 to 4 times in a day.
I am adding the attachment of log file please help me anyone know identified this problem.
Thanking you,
Ranga Kishore
9959344436
rangakishore Fri, 08/31/2007 - 00:36
Hi Chris,
We are using 4.0.155.5 version, Please clarify any bugs on this firmware.
Thanking youm
engineerangelo Mon, 09/17/2007 - 18:01
What's the specific model of your 4402? How many access points do your controller support?
Can you also check if the uplink or distribution ports on your WLC goes up and down. Thanks.
MIsatchenko Mon, 09/17/2007 - 19:12
Have you physically reset the AP's?
We had similar problems and after the reboot, they never disassosiated again.
Also, you could try to set the Primary Controller name on the Access Points
Trending Topics - Security & Network
