Anyconnect Client with IOS Webvpn - Multiple Installs
Aug 30th, 2007
Has anyone worked out how to install multiple anyconnect packages (to support different versions)? When I do a webvpn svc install it overwrites the existing platform, and we need to support all of the different platform types. Many thanks
alistaircowan Thu, 09/06/2007 - 02:33
Thanks, We dont use the SDM on our devices, but looking at the screenshots it seems to only support one package at a time as well. Do you know of anyone who has installed support for more than one platform?
Massimiliano Tognon Sat, 11/17/2007 - 00:41
We have the same problem,has anyone already tried to configure multiple anyconnect client on ios system 12.4(15)T ?
Many thanks
Max
adns_jeremy Thu, 05/08/2008 - 07:57
I'm having the same issue; not able to install multiple packages (pc, mac):
Router: 3825
IOS: 12.4(11)XW5; c3825-adventerprisek9-mx.124-11.xw5.bin
SSL VPN Clients:
Windows: anyconnect-win-2.2.0128-k9
Mac: anyconnect-macosx-i386-2.2.0128-k9
jechoi Wed, 07/09/2008 - 17:04
Seems like ios can only support one pkg in the router. ASA is capable of multiple packages.
I wonder if this feature will be available in the next ios release.
michael.maciag@... Sat, 10/11/2008 - 13:23
I was able to install windows and mac packages from the command line using the webvpn install command with sequence numbers
Router: 3825
IOS: 12.4(13r)T10; C3825-ADVENTERPRISEK9-M
benlemasurier Thu, 03/31/2011 - 12:50
Is this still an issue? I'm able to install multple packages with sequencing, but platform detection for anything but the primary (sequence 1, windows) fails.
Alex Pfeil Mon, 05/20/2013 - 05:58
I just figured out the answer.'
I had a 2.5.60005 version installed on my ASA with Windows NT running.
I wanted to upgrade to the latest version of the Cisco Secure Mobility Client.
I put the anyconnect-win-3.1.03203 package at the top, but I did not add the regular expression, and presto.
I was still able to connect with the win-2.5.6005 anyconnect.
I even removed the regular expression from the 6005 image and was still able to establish a connection.
**NOTE** - I was not able to browse to the portal and click start anyConnect with the 6005 image still on my machine, but I was able to open up the client and connect directly.  When I uninstalled the client, and connected to the portal and clicked on start anyconnect, it installed the latest client.
Please rate helpful post and mark this question as answered.
Alex
