How can I use my old Analog phones with Call manager 4.0
divyendu_bhatt
Hello All,
I have a query I have old Anlog phones with me and company dosnt want to throw those old phones and I just have two ports available one for voice and one for data.Now how should I use my old phones if at all I want to use Call manager.Do I need to by IP phones only.What exactly can be the solution.Do we have any converter that I can use to integrate old phones (Panasonic) with call manager.
Thanks in Advance
Divyendu
lpezj
Level 7
Level 7
If you have few phones, you can use Cisco ATA-186 that it porvides you with two analog ports. Cisco ATA is an 'analog to IP' device converter.
If you have a lot phones you can use an Cisco VG-224, which provides 24 analog FXS ports.
Hope this helps,
Juan Luis
Hello Luis,
Thanks a lot for your help, I was totally blank now i got the right path to move....
Divyendu
Juan Luis
azfarlashari
Dear, If you have more than two phones then you can use VG248 - that will give you the option to use 48 analog phone with CCM
