ICMP Monitoring of remote offices - suggested tools?
Aug 30th, 2007
We have a number of remote branches (several hundred) connected via ADSL (using IPSEC tunnels) and I would like to simply monitor the up/down status of the connections from head office to each remote site.
Can anyone recommend a simple, cost-effective Windows-based monitoring tool to carry out this task?
I'm thinking that a simple ping (ICMP) probe of some sort would be sufficient - preferably with some sort of web-based front-end to show which links are up or down.
Can anyone recommend any network monitoring tools that would achieve this?
Overall Rating: 3 (3 ratings)
purohit_810 Thu, 08/30/2007 - 06:24
  • Silver, 250 points or more
ALCAMY NETMON is very good and reliable tool.
It also gives you report.. you can also monitor server by specific port.
Simple to maitain..
Dharmesh Purohit
mitchen Thu, 08/30/2007 - 06:30
Thanks, I'll have a look at that.
Has anyone any more suggestions?
purohit_810 Thu, 08/30/2007 - 06:46
It has also WEB based Interface and reporting.
Second, You can float by that software EMAIL also.. for whole days Outage.
Dharmesh Purohit
Anonymous (not verified) Thu, 08/30/2007 - 08:14
avmabe Thu, 08/30/2007 - 08:18
  • Bronze, 100 points or more
If you want something windows based, I'd recommend What's UP. It's been around a LONG time and quite cost effective.
http://www.ipswitch.com/products/whatsup/index.asp
There are a ton of simple fault mgmt tools, but that one will work great on windows and isn't too expensive.
Now, if you had a linux box I would recommend the FREE cacti http://cacti.net because it has a great up/down/email notify/webpage.
Anonymous (not verified) Thu, 08/30/2007 - 08:25
srue Thu, 08/30/2007 - 10:25
  • Blue, 1500 points or more
referring to the person who recommended cacti, it also runs on windows. on the other hand, there is always Perl...or as its referred to in windows - activestate. something like a simple ping would be trivial to program, even for a non-coder type.
lyndontynes Thu, 08/30/2007 - 10:57
Mitchen,
I would use SNMPc v7. It's a somewhat enterprise solution for smaller implementations. Since it's not as robust as, say, HP OpenView's NNM, it still gives you the basic up/down status and is very easy to learn.
