Error with ASA5505
Aug 30th, 2007
Ok i just got my ASA5505 setup and running and when i try and connect to it i am getting the following errors
Group= DefaultRAGroup,IP =*.*.*.* Removing peer from peer table failed, no match!
Group= DefaultRAGroup, IP=*.*.*.* Error: Unable to remove peer TblEntry
when we are trying to connect we are not using the DefaultRAGroup for anything. Any help on this is really apprecitated
Cory Andrews
grahambartlett Mon, 09/03/2007 - 04:21
I see in your tunnel group, you are authenticating against, authentication-server-group group1, for group1 you dont have an IP for the server,
aaa-server group1 (outside) host
Can you add your server IP and then test..
cory_ty87 Fri, 09/07/2007 - 12:33
Did that and sitll getting the same error as before.
Sorry it took so long to respond have been real busy.
