IPSEC passthrough on ASA5505
lifecareit
Trying to set up ASA 5505 to allow IPSEC passthru for AT&T Global network Client VPN.
5 Replies 5
jeremyault
Create an ACL to allow the traffic to pass? Assuming you're using esp and ike.
access-list 111 permit esp
access-list 111 permit udp eq isakmp
access-group 111 in interface outside
That will let it pass through un-natted. If you need to nat then you'll need to create a static nat.
Did that part already...looks like a static nat is in order.
Oh yeah, I just remembered, if the clients are using NAT traversal, you'll need to permit the UDP port being used - most often UDP 10000 but could be whatever port NAT-T is set to.
JORGE RODRIGUEZ
Level 10
Level 10
These are the IPsec vpn ports that need to be allowed through.
udp 500
udp 4500
protocol 50 esp
Jorge Rodriguez
