"Rogue" MeetMe Conferences
Aug 30th, 2007
We have an intranet calendar for scheduling MeetMe conferences so we can avoid over-running available seats. Is there anyway to identify the host of a MeetMe conference while it is in use, or even after it ends? Thanks.
bwalchez Wed, 09/05/2007 - 13:24
Go to Cisco Callmanager Serviceability page
Open on the Menu .... Tools-->Real-Time Monitoring Tool
There on the left pane menu select your callmanager go to the Cisco HW Conference Bridge
Device folder-->Double click on HWConferenceActiveParticipants on the ObjectInstances
window select the CFB that meetme conference is using.
elbyte Wed, 09/05/2007 - 14:31
Thanks for your response. We are running CUCM 5.1 and the Realtime Monitoring Tool is a stand alone program on a pc. The menu options are quite a bit different than the old version. I am having no luck trying to find the HW Conference Bridge Device.
elbyte Tue, 09/11/2007 - 10:03
It was suggested that I should mention here that we are using a software conference bridge, not hardware. Thanks.
