IPM DB Server Not starting
Answered Question
Aug 30th, 2007
Is there a way to re-initialize the IPM Database ?
The IPB DB Server is not starting. We never used IPS before, so there is no useful data in the DB.
Or Is there another way to fix this ?
Naman
Correct Answer by Joe Clarke about 9 years 6 months ago
You can reinitialize the IPM database using:
ipm dbclean
The ipm command is found under /opt/CSCOipm/bin on Solaris and by launching the IPM Command Prompt on Windows.
Overall Rating: 5 (1 ratings)
Joe Clarke Thu, 08/30/2007 - 09:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of IPM?
Correct Answer
Joe Clarke Thu, 08/30/2007 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
ipm dbclean
