IPSec Tunneling informations needed
Aug 30th, 2007
I have a Watchguard Firebox 3 in a remote site and a PIX 515e on my local site and want to have them communicate each other via a IPsec Tunnel and I don't really know how to perform that!
Does anyone can tell me the path ?
JORGE RODRIGUEZ Thu, 08/30/2007 - 11:29
Hi Guy, I could not comment on the Watchguard Firebox firewall on the how to stablish a vpn tunnel between two sites, however, you can take a look at some examples on how to configure site-to-site vpn between two pixes, read the principle on site-to-site vpn tunnel and you could get some support from the firebox vendor on how to create a site to site tunnel on their boxes.
Example of lan-to-lan vpn tunnel (CLI )
Example of lan-to-lan vpn tunnel (PDM )
Also, for the PIX515 side ensure you have
proper VPN-3DES-AES license as this is needed to enable site to site vpn tunnels.
gbordeleau Thu, 08/30/2007 - 12:00
Thanks Jorge,
I already have the proper VPN-3DES-AES license since I have installed a tunnel between our Europe Office and North America one. Thanks for the suggestion. I will have a look on Whatchguard side.
JORGE RODRIGUEZ Thu, 08/30/2007 - 12:19
No problem,let us know how you make out on the watchguard fw side and pix tunnel.. check this forum as there is always a posibility someone out there may have done it and post comments on this thread..
