Aug 30th, 2007
I have 3 routers A, B and C
All 3 routers are connected by vlan 2
This is there address on vlan 2:
B and C have vlan6 and are configured with HSRP
HSRP (C is active)
Router A is learning network with EIGRP
Routing entry for
Known via "eigrp 100", distance 90, metric 28416, type internal
Redistributing via eigrp 100
Last update from on FastEthernet0/1, 00:36:09 ago
Routing Descriptor Blocks:
*, from, 00:36:09 ago, via FastEthernet0/1
Route metric is 28416, traffic share count is 1
Total delay is 110 microseconds, minimum bandwidth is 100000 Kbit
Reliability 255/255, minimum MTU 1500 bytes
Loading 1/255, Hops 1, from, 00:36:09 ago, via FastEthernet0/1
I want router A to choose the active router ( not the standby. What should I do?
Overall Rating: 3 (3 ratings)
Jon Marshall Thu, 08/30/2007 - 11:12
Can you do a
"sh ip route | begin"
I ask because i believe that both paths will be being used as they are equal cost so EIGRP will install both into the routing table.
The other thing i would say is that routers do not use HSRP, this is for end devices only. Routers uses the physical interface addresses.
If you really want to ensure that all traffic goes via the active HSRP router you could use metrics or PBR but these would not dynamically change if the active interface goes down. Is there a reason you want to do this ?
Edit - should also have said the asterix in the output next to the entry is not signifying the chosen route rather the asterix moves between the 2 routing entries as each route is used to forward packets.
msaulnier Thu, 08/30/2007 - 12:28
The reason I want to do this... I didn't want to have asymmetrical routing. But I think I don't really need to.
sh ip route | begin
D [90/28416] via, 02:49:24, FastEthernet0/1
Mohamed Sobair Thu, 08/30/2007 - 12:58
By default Eigrp will load balance across equal cost paths, but as you posted, its not load balancing a cross both paths.
To view all paths available for the Network, issue (sh ip eigrp topolgy) command. and since you have one active route in the routing table, it does mean its a successor. A feasable successor is a vailable second path can be used with the (variance command).
In your case, you want the router to take the other path for Network, you can acheive this by higher the delay of Router' B Interface as follows:
Interface x
delay 120
* Be carefull not increasing the delay of the interface two much till the route wont be seen as Feasible Successor.
Another way, is to configure (Offest-List) and & increase the Delay of Specific Network as follows:
router eigrp 100
offest-list 10 out 20 interface x
access-list 10 permit
This will increas the delay of subnet by 20 when the router sends an Eigrp update, so when it reaches router A, Router A will decide to go through router-C to reach Network
Mohamed Sobair
Jon Marshall Thu, 08/30/2007 - 13:10
Hi Mohamed
It is load balancing across both links. If you look at the output of the "sh ip route | begin" you can see that EIGRP has installed 2 routes for the destination subnet into the routing table. So there are two active routes in the routing table.
And from the output of the original post you can see that both routes have an equal cost so the concept of a feasible successor does not come into play.
So yes, as i said you can influence this with metrics but why would you want to. If you do per-destination load-balacing then asymetric routing is not an issue anyway.
Mohamed Sobair Fri, 08/31/2007 - 11:12
Hi Jon,
I didn't see the next active route, yes its load sharing accross both paths.
But As I understand, his objective is to make sure the returned traffic is coming through the Active Router,so the this has nothing to do with HSRP but Metric influencing, AM I Right?
Or correct me if I mistaken or mis understood some thing.
Mohamed Sobair
Jon Marshall Fri, 08/31/2007 - 13:08
Hi Mohamed
No need to apologize at all. Just wanted to point out that it was using both paths.
You are right but i think the original poster assumed that it was using only the standby router and it was in fact using both. And i was trying to emphasize that EIGRP as a routing protocol does not use HSRP.
The metric solution you gave would work fine but i just wondered why do that ?
Mohamed Sobair Fri, 08/31/2007 - 13:34
Hi Jon,
Yes you are right, since HSRP is independent Of EIGRP traffic in his case.
May be he just have specific approach or some thing in mind, but I agree with u your point is definetly valid.
Mohamed Sobair
