Warning message
Trunked port in router and MTU
vishwancc Thu, 08/30/2007 - 13:23
As far as i know you can do it .
but it should be
conf t
- interface
- ip tcp adjust-mss 1200
For truncks that are in between two Cisco 3750 switches, is there a way to do the same thing?
sample switch config:
interface FastEthernet1/0/33
description Trunk Connection via IPSEC INE
switchport trunk allowed vlan 1,6,58,59,222,1002-1005
switchport mode trunk
speed 10
duplex full
spanning-tree port-priority 240
spanning-tree cost 5000
no shut
nambi_gct Fri, 08/31/2007 - 00:01
  • Bronze, 100 points or more
Mike,you can use "mtu " command to do this.IP MTU by default is adjusted according to MTU of the physical interface.if you need mtu size greater than 1500 please enable jumbo settings with "system jumbomtu" command."ip mtu" command on l2 interface is not meaningful.
