CSM not load-balancing properly
Aug 30th, 2007
Folks,
I'm seeing that CSM is not loadbalancing properly to all the servers in the serverfarm.
I simulated a failover of one of the servers TS05 and brought it back. After coming online, CSM sent no traffic to that server, as shown below:
C7606-1#show mod csm 1 serverfarms name WHTTP detail | i OPER
TS01-RADIO, weight = 8, OPERATIONAL, conns = 2
TS02-RADIO, weight = 8, OPERATIONAL, conns = 4
TS03-RADIO, weight = 8, OPERATIONAL, conns = 2
TS04-RADIO, weight = 8, OPERATIONAL, conns = 4
TS05-RADIO, weight = 8, OPERATIONAL, conns = 0
TS06-RADIO, weight = 8, OPERATIONAL, conns = 1
TS01-RADIO, weight = 8, OPERATIONAL, conns = 1
TS02-RADIO, weight = 8, OPERATIONAL, conns = 3
TS03-RADIO, weight = 8, OPERATIONAL, conns = 1
TS04-RADIO, weight = 8, OPERATIONAL, conns = 3
TS02-RADIO, weight = 8, OPERATIONAL, conns = 1
TS03-RADIO, weight = 8, OPERATIONAL, conns = 0
TS04-RADIO, weight = 8, OPERATIONAL, conns = 2
TS06-RADIO, weight = 8, OPERATIONAL, conns = 2
TS06-RADIO, weight = 8, OPERATIONAL, conns = 3
TS06-RADIO, weight = 8, OPERATIONAL, conns = 4
My config is attached with this post:
Can there be anything wrong with my VARIABLES?
C7606-1#show mod csm 1 variable | i SLOW
REAL_SLOW_START_ENABLE 1
C7606-1#
Overall Rating: 5 (2 ratings)
Syed Iftekhar Ahmed Thu, 08/30/2007 - 15:06
  • Blue, 1500 points or more
slow-start mode ensures that a newly operational server should received less number of new load-balanced connections than other servers. This would prevent the newly activate server from being overloaded with many consecutive new connections because of least opened connections selection method.
The configurable range for this variable is 0 to 10. The setting of 0 disables the slowstart feature. The value from 1 to 10 specifies how fast the newly activated server should ramp up. The value of 1 is the slowest ramp up rate.
I would suggest changing this variable value to 2 or 3(default value).
Syed
kasiddiq Thu, 08/30/2007 - 15:24
Syed - I will try the change you suggested. However, I didn't see any traffic going to the newly activated server (TS05). Even after an hour of testing.
But I'll change the value and see if it resolves the problem.
Thanks!
Kashif
kasiddiq Fri, 08/31/2007 - 09:16
I configured roundrobin for one serverfarm and it seems to work fine....
C7606-1#show mod csm 1 serverfarms name RADIUS detail | inc OPER
TS01-RADIO, weight = 8, OPERATIONAL, conns = 2280
TS02-RADIO, weight = 8, OPERATIONAL, conns = 2276
TS03-RADIO, weight = 8, OPERATIONAL, conns = 2277
TS04-RADIO, weight = 8, OPERATIONAL, conns = 2273
TS05-RADIO, weight = 8, OPERATIONAL, conns = 2275
TS06-RADIO, weight = 8, OPERATIONAL, conns = 2272
TS01-RADIO, weight = 8, OPERATIONAL, conns = 2316
TS02-RADIO, weight = 8, OPERATIONAL, conns = 2312
TS03-RADIO, weight = 8, OPERATIONAL, conns = 2313
TS04-RADIO, weight = 8, OPERATIONAL, conns = 2310
TS05-RADIO, weight = 8, OPERATIONAL, conns = 2312
TS06-RADIO, weight = 8, OPERATIONAL, conns = 2309
But the serverfarm with leastconns slowstart 60 is still not distributing traffic accordingly.
C7606-1#show mod csm 1 serverfarms name WHTTP detail | inc OPER
TS01-RADIO, weight = 8, OPERATIONAL, conns = 801
TS02-RADIO, weight = 8, OPERATIONAL, conns = 0
TS04-RADIO, weight = 8, OPERATIONAL, conns = 0
TS06-RADIO, weight = 8, OPERATIONAL, conns = 0
TS01-RADIO, weight = 8, OPERATIONAL, conns = 659
TS01-RADIO, weight = 8, OPERATIONAL, conns = 739
Syed Iftekhar Ahmed Fri, 08/31/2007 - 09:33
Which Code are you running on CSM. There is a similar bug( CSCei26434 leastconn sending all new conns to a single server) which was fixed in 4.2(3a).
Syed Iftekhar Ahmed
kasiddiq Fri, 08/31/2007 - 09:36
I am running 4.2(3)
C7606-1#show mod version
Mod Port Model Serial # Versions
1 4 WS-X6066-SLB-APC SAD0744050P Hw : 1.7
Fw :
Sw : 4.2(3)
2 48 WS-X6748-GE-TX SAD0902013H Hw : 2.5
Fw : 12.2(14r)S5
Sw : 12.2(18)SXE6b
Sw1: 8.6(0.66)ROC16
WS-F6700-CFC SAD093302Y8 Hw : 2.0
3 48 WS-X6748-GE-TX SAD074803WL Hw : 1.2
Fw : 12.2(14r)S5
Sw : 12.2(18)SXE6b
Sw1: 8.6(0.66)ROC16
WS-F6700-CFC SAD07430896 Hw : 1.1
6 2 WS-SUP720-3BXL SAL09486VL2 Hw : 4.3
Fw : 8.4(2)
Sw : 12.2(18)SXE6b
Sw1: 8.6(0.66)ROC16
WS-SUP720 SAL09497EFG Hw : 2.3
Fw : 12.2(17r)S2
Sw : 12.2(18)SXE6b
WS-F6K-PFC3BXL SAL0949722R Hw : 1.6
So 4.2(3a) is upgrade for 4.2(3)?
Syed Iftekhar Ahmed Fri, 08/31/2007 - 09:57
CSM code, 4.2(3) was deferred and was removed from CCO. 4.2(3a) replaced it at that time.
Syed Iftekhar Ahmed
kasiddiq Thu, 10/18/2007 - 15:05
Folks - I upgraded the code to 4.2(6) and thought that bug CSCei26434 was solved, but still see the same error where CSM is not balancing properly.
No Traffic Running:
TS01-RADIO, weight = 8, OPERATIONAL, conns = 0
Started Traffic
TS01-RADIO, weight = 8, OPERATIONAL, conns = 60
TS01-RADIO, weight = 8, OPERATIONAL, conns = 101
TS01-RADIO, weight = 8, OPERATIONAL, conns = 188
The newly ALIVE server passed the probe test:
C7606-1#show mod csm 1 probe detail | inc 102
192.168.122.102:1813 RADIUS RADIUS (default) OPERABLE
192.168.122.102:9202 WSP_SCL WSP_SCL (default) OPERABLE
192.168.122.102:9201 WSP_CO WSP_CO (default) OPERABLE
192.168.122.102:9200 WSP_CL WSP_CL (default) OPERABLE
192.168.122.102:8080 WHTTP WHTTP (default) OPERABLE
192.168.122.102:8080 TP_8080 TP_8080 (default) OPERABLE
192.168.122.102:7080 PUSH_WWW PUSH_WWW (default) OPERABLE
Still no connections:
TS01-RADIO, weight = 8, OPERATIONAL, conns = 583
C76061#
Brought another server on-line:
C7606-1#
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: TCP health probe re-activated server 192.168.122.106:8080 in serverfarm 'WHTTP'
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: TCP health probe re-activated server 192.168.122.106:8080 in serverfarm 'TP_8080'
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: TCP health probe re-activated server 192.168.122.106:7080 in serverfarm 'PUSH_WWW'
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: UDP health probe re-activated server 192.168.122.106:9200 in serverfarm 'WSP_CL'
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: UDP health probe re-activated server 192.168.122.106:1813 in serverfarm 'RADIUS'
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: UDP health probe re-activated server 192.168.122.106:9201 in serverfarm 'WSP_CO'
C7606-1#
C7606-1#
1w4d: %CSM_SLB-6-RSERVERSTATE: Module 1 server state changed: SLB-NETMGT: UDP health probe re-activated server 192.168.122.106:9202 in serverfarm '
No connections to the NEW Server even
TS01-RADIO, weight = 8, OPERATIONAL, conns = 2988
kasiddiq Thu, 10/18/2007 - 15:08
SW versions:
C7606-1#show mod | inc SLB
1 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD0744050P
C7606-1#show mod
Mod Ports Card Type Model Serial No.
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAD0902013H
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAD074803WL
6 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL09486VL2
Mod MAC addresses Hw Fw Sw Status
1 000d.bcaf.d328 to 000d.bcaf.d32f 1.7 4.2(6) Ok
2 0011.bb2b.67d0 to 0011.bb2b.67ff 2.5 12.2(14r)S5 12.2(18)SXF7 Ok
3 000e.38c6.7d10 to 000e.38c6.7d3f 1.2 12.2(14r)S5 12.2(18)SXF7 Ok
6 0013.c42e.ee90 to 0013.c42e.ee93 4.3 8.4(2) 12.2(18)SXF7 Ok
Mod Sub-Module Model Serial Hw Status
2 Centralized Forwarding Card WS-F6700-CFC SAD093302Y8 2.0 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAD07430896 1.1 Ok
6 Policy Feature Card 3 WS-F6K-PFC3BXL SAL0949722R 1.6 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL09497EFG 2.3 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
6 Pass
C7606-1#
CSM Variables:
variable value
ARP_INTERVAL 300
ARP_LEARNED_INTERVAL 14400
ARP_GRATUITOUS_INTERVAL 15
ARP_RATE 10
ARP_RETRIES 3
ARP_LEARN_MODE 1
ARP_REPLY_FOR_NO_INSERVICE_VIP 0
ADVERTISE_RHI_FREQ 10
AGGREGATE_BACKUP_SF_STATE_TO_VS 0
COOKIE_INSERT_EXPIRATION_DATE Fri, 1 Jan 2010 01:01:50 GMT
DEST_UNREACHABLE_MASK 0xffff
FT_FLOW_REFRESH_INT 0
FTP_CLOSE_DATA_CONN 0
GSLB_LICENSE_KEY (no valid license)
HTTP_CASE_SENSITIVE_MATCHING 1
HTTP_URL_COOKIE_DELIMITERS /?&#+
INBAND_STATE_CHANGED_MSG_RATE 4
INFINITE_IDLE_TIME_MAXCONNS 1024
MAX_PARSE_LEN_MULTIPLIER 1
NAT_CLIENT_HASH_SOURCE_PORT 0
variable value
NO_RESET_UNIDIRECTIONAL_FLOWS 0
REAL_SLOW_START_ENABLE 5
ROUTE_UNKNOWN_FLOW_PKTS 0
CSM_FAST_FIN_TIMEOUT 10
SASP_CSM_UNIQUE_ID Cisco-CSM
SASP_FIRST_BIND_ID 65520
SASP_GWM_BIND_ID_MAX 1
SASP_SCALE_WEIGHTS 0
SSL_DEFAULT_STICKY 0
SWITCHOVER_RP_ACTION 0
SWITCHOVER_SP_ACTION 0
SYN_COOKIE_INTERVAL 3
SYN_COOKIE_THRESHOLD 5000
TCP_ACCEPT_RST_EQU_NEXT_GET_SEQ 0
TCP_MSS_OPTION 1460
TCP_WND_SIZE_OPTION 8192
VSERVER_ICMP_ALWAYS_RESPOND false
XML_CONFIG_AUTH_TYPE Basic
MSTS_RDP_VIP_LIST
MAX_VSERVERS_PER_VIP 10
SECURE_HTTP_PORT 443
SECURE_HTTP_SSL_METHOD 0
SECURE_HTTP_TFTP_HOST_IPADDRESS
variable value
SECURE_HTTP_SERVER_CERTIFICATE
SECURE_HTTP_PRIV_KEY_FILE
SECURE_SASP_ENABLE 0
SECURE_SASP_SSL_METHOD 0
SECURE_SASP_TFTP_HOST_IPADDRESS
SECURE_SASP_SERVER_CERTIFICATE
SECURE_SASP_PRIV_KEY_FILE
NO_TIMEOUT_IP_STICKY_ENTRIES 0
MAX_COOKIE_SIZE 0
SASP_RETRY_COUNT 8
C7606-1#
